Results 1 to 18 of 18
Thread: New car engine problem?
    vs
    Mar 2011
    australia
    Default New car engine problem?
    Hey guys
    so i just brought my beautiful vz sv6 today off a auction
    2005 model
    when i started her up there was this crackling noise? like something in side the engine bouncing around
    now i drove it and it drives like new, just went i turn it on and its on park, its a really loud crackling noise
    anyone tell me what it could be? can also hear it when driving
    no check engine or anything comes when i start the car? says system is fine
    thanks!
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    VZ V6, i'm guessing that the timing chain might be starting to stretch. I hope for your sake that thats not the case.
    But you should take it to a mechanic to get it checked out, could be something simple.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    vs
    Mar 2011
    australia
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by vs v6 View Post
    ahh how much is timing chain?
    Approx
    I'm not sure exactly of the cost sorry. But I know someone else who had the same problem. He had to get the timing chain, tensioners, etc. Problem was that his timing chain stretched too much and jumped a tooth or two and it would run after that.
    A few members of this forum have had to get their timing chains replaced on the Alloytecs, hopefully they will be able to give you an idea.
    vs
    Mar 2011
    australia
    thanks for that
    also do you have any idea how go switch fog lights on
    im use to my vs with a switch but no switch on the vzlol
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    thanks for that
    No problem.
    To switch the fog lights on, turn the parkers on, then pull the switch (headlight switch) towards you, if that makes sence.
    VZ Calais
    Jan 2012
    VZ SV6
    Jan 2012
    Woop woop
    I have a very similiar problem!
    • In the mornings, when i start my car, it always roars then makes this loud cracklin sound. This stops after 3 seconds.
    • But if ive been driving the car around then turn off the engine and turn it back on again it doesnt crackle.
    • If i drive to work then park my car for the day which gives it 8hours to rest then start the car for the cruise home it crackles?
    Seems to me whenever the engine is cooled down it crackles when starting up.
    Also my car doesnt crackle when driving.
    Whyyyyyy is this???
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    lack of lubrication around the timing chain, normal and nothing to worry about. mine has been doing it for 80,000km
    Spoken by a true member of The Committee
    vs
    Mar 2011
    australia
    thanks alot for the fog light help
    well if its noot a major problem with that noise then i grabbed my self only cost 5300 for vz sv6 with the guards
    il make a thread soon
    VZ SV6
    Jan 2012
    Woop woop
    Woah that puts my mind at ease! Thank you.
    Btw is the timing chain easy to locate mate?
    VZ SV6
    Jan 2012
    Woop woop
    VY S V6 Ute Series II 2004
    Nov 2009
    Hey guys
    2005 model
    thanks!
    Is there plenty of engine oil in it? Could be running low or more likely its the wrong grade. 10W-30 required I think.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by Svu6 View Post
    Also what would i use to lubricate the timing chain?
    check your dipstick mate.. the timing chain is covered by the timing chains are covered by the timing chain cover. Which is fed oil from oil valleys, so if your engine has oil, so does your timing chain
    Life starts at 200km/h
  15. #15
    SV6 3.6L Alloytech
    Dec 2011
    Collie
    i asked for a quote to get my timing chain changed it was over 3 grand the mechanic told me, because you need to by the rails and everything they run on because its all made of plastic. So if its stretched you need to replace everything along with it. my car has engine knocking in cylinders 2,3,4 and 5 unsure how to fix the problem not even a mechanic can tell me they all said they will need to pull it apart first before they can give me an idea on how to fix it. Anyone know if this is true or can it be fixed another way?
  16. #16
    May 2009
    Gold Coast
    What I meant by lack of lubrication is that the oil drains back to the sump, so once all the oil drains back, the chain is not as lubricated as in normal driving, as the oil has not circulated through the engine fully on first startup. Only get worried if it starts being very rattly for majority of driving
  17. #17
    vs
    Mar 2011
    australia
  18. #18
    vs
    Mar 2011
    australia
    took it today cause i had some time
    and the mechanic said it might be the cyclinders? is that possible? with some knocking noises
  1. vn ss engine problem
    By clazy69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2011, 03:41 PM
  2. Vt engine problem
    By wells89 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2011, 03:26 PM
  3. engine problem
    By philthestud in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-06-2010, 06:16 PM
  4. 202 Engine Problem
    By mainpath in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-04-2010, 03:33 PM
  5. engine problem
    By Budz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-09-2008, 08:18 PM
