broke the oil filter cover please help????
Ricksta
Perth, Western Australia
VZ SV6 impulse blue
hey all i broke the oil filter cap. how do i remove the remaining cap or am i able to remove the whole reservoir? i tried searching on the forum but just kept coming up with how to remove oil filter.
any help would be much appreciated
ben315vz
Donating Member
Tamborine Mountain, QLD
'05 Holden VZ Calais V8
Yeah, you should never do them up too tight. I only tighten them until it stops. Once you can't see the seal, it wont leak.
You can try removing the rest of it with an oil filter remover maybe, but you could end up damaging the the housing as well.
I have come across a few of these filters that were very tight to undo, but this has never happened.
Ricksta
VZ SV6 impulse blue
i didn't tighten it up i only just got the car 2 weeks ago, i've been doing my miss's car for a few years now and have always tightened to 25nm like the cap say's and have never had a problem. the ar$ehole i bought the car off said his mechanic did all the work on his car. but i could tell today that someone had tried to remove it b4 and had slightly rounded the bolt which lead's me to think did the filter even get changed on it's last service?
Ricksta
VZ SV6 impulse blue
so how do i safely remove the reaming cap or am i able to remove the whole housing from the motor to get at it better?
ben315vz
Donating Member
I have never removed the whole housing so i'm not sure if it is easy to do or not.
I would try using something like this to get it off:
Only thing is, being alloy, it might not grip well.
Ricksta
VZ SV6 impulse blue
i dont think that would work the amount of force i used to break the bolt didn't even make the cap budge 1mm
Pitty
VY
can't you use one of these?
oil filter wrench
edit: nevermind probably wont be strong enough
maybe this
Ricksta
VZ SV6 impulse blue
i don't have one but i suppose i could try? hasn't someone had this happen to them? i read some where someone did but couldn't find the post? would like to know what they ended up doing to remove it
Potta9
33
Camden
Ve r8 , B2600
I'd recommend a cat type filter strap I use mine everyday and will hand my 1/2" breaker bar with a pipe on the end! (yes I've had filters that tight)
If that doesn't work I'd go the chisel and hammer to shock it free at worse case scenario.
Ricksta
VZ SV6 impulse blue
^^^^ i'm thinking the cold chisel and hammer is the way to go :) just don't wanna damage the housing. holden quoted me $170 for a replacement cap :(
