scrounga
- Jan 28, 2012
- 25
- 0
- 0
- Location
- Canberra, Australia
- VE Omega ute. VZ Monaro (Sting Red)
Hi guys, Just want to know if anyone has a better theory. On our way back from Melbourne to Canberra today we stopped to change drivers. Shut the engine down and when I can back from the dunny it had dumped a heap of coolant. There was no coolant trail and nothing under the car except where the coolant had be dumped from the over flow bottle. Thought it MAY be a hot soak so took it for a quick run further along the highway with a very quick rise to limp home mode. RACV arrived and topped up the coolant and let it idle for a while with no problems so I followed him back to the Holden stealership and the temp was perfect with the air con on for the next 5-7 kms. When I stopped to say thanks for the help I looked back at the car, which was still running, to see it again dumping coolant. Long story short got brought home on the back of a truck. So the following occured:
Gen III V8.
Only overheated when the car was stationary with engine idling or switched off. Probably/ maybe could have driven home if I didn't stop. To far to chance it.
Thermos were working fine and hard.
No sign of a leak anywhere. Engine bay and under the car bone dry except for passenger side front where coolant was being force out of the overflow bottle.
No sign of a blown head gasket as engine was smooth and powerful and oil clean. Nice smooth idle.
Temp normal (1/4) when sitting on 110km/h before I stopped the first time and after visit by RACV.
Had the coolant replaced at the last service and has already been to Melbourne and back since then.
Conclussion: I suspect the radiator cap as this is the only way coolant can get to the overflow bottle but the dealership didn't have one (insert comment here) so I couldn't try it. I will get one tomorrow and keep my fingers crossed. I have been told by my son that VZ's are known to have radiator caps that fail. I have checked mine and it's the original but looks OK but I am suspicious of it. Besides it's 7 years old so a new one won't hurt and it's the cheapest and easiest place to start.
Any ideas on my conclusion would be welcome.
Thanks in advance.
PS when/if I have fixed the problem do the Gen III's need bleeding like the 6's???
Stu.
Gen III V8.
Thanks in advance.
Stu.
