My 2004 engine mounts need replacing but the mechanic at utlra tune said it would cost $350 labour to fix.
I bought some new mounts from supercheap for $127 but was wondering what needs to be done to replace them yourself? And is it as hard to do as the vs v6?
Did you end uo doing this. As i am about to do mine in the near future.
would also like to know
depends on what side of the motor its on... drivers side isn't to bad.... passenger side is a bit harder.. the a/c compressor is in the way a bit
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Drivers side is a pain if u have abs, i found that passenger side was easier
