Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Diff gear Question
    VZ Alloytec Sedan, VS L67 Ute
    Nov 2008
    Darwin
    Default Diff gear Question
    Does anyone know what the diff ratio is in the standard VZ Exec sedan v6 auto? Wanna put an LSD diff in it and not sure weather to keep the same ration or change it.
    If i end up changing what should i change it to? not building a race car just wanna give it a bit more of a kick.
    Sorry dont know much about diffs
    cheers james
    2005 VZ Alloytec Sedan, 3.46 LSD, 19" BSA alloys, 2.25 twin xforce system Build Thread
    WTB: VZ HBD Body lip front and rear
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Standard is 3.08:1, a good upgrade is the 3.46:1 ratio usually found in manual ss commodores so it should be fairly easy to find one
    Spoken by a true member of The Committee
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    There is usually a few LSD 3.46's floating around on ebay at any one time and most are LSD as they come out of V8's, HSV and SS's.
    3.46 is probably the best ratio for a stock to lightly modified V6 as it gives it kick without really hurting fuel ecomomy, in fact around town it usually gets better once you stop enjoying the new found squirt.
    Highway fuel economy stays pretty much the same.
    2004 VZ SV6 5-Speed Auto
    Jan 2011
    Cardiff, NSW
    Quote Originally Posted by Surfwagon View Post
    What are the rev differences between stock and 3.46? And how much does it affect acceleration?
    May 2009
    Gold Coast
    My 1/4 mile changed by .2 seconds, but 0-100 was about half a sec quicker, that's with an sv6
    '05 vz sv6
    Oct 2010
    When you changed your diff who recalibrated your speedo or how'd you do it?
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by morphix View Post
    At 100kph difference is about 200 revs more with 3.46 and you will notice the extra punch from the 3.46's.
    Nov 2008
    Darwin
    I know the computer will have to be calibrated but if i replace a 3.08:1 with a 3.46:1 will it bolt straight in or will some things have to be changed to make it fit?
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    May 2009
    Gold Coast
    I took my car to Holden and they recalibrated it for 60 bux
  1. Diff Gear for VE
    By ssavage in forum VE Holden Commodore (2006 - 2013)
    Last Post: 22-05-2013, 12:16 PM
  2. Diff gear question
    By STL17 in forum V6 Development And Modification
    Last Post: 01-12-2011, 10:08 AM
  3. [QLD] WTD- Diff gears or whole lsd/spooled diff with gear set
    By Eliminator in forum Swap / Wanted to Buy / Trade
    Last Post: 21-07-2010, 06:29 PM
  4. Gear ratios for diff
    By Sgt Santa Cruz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2010, 01:14 PM
  5. diff gear question
    By VH commodore in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2009, 07:09 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
