Pedders Suspension quote
rowe147
33
VZ executive
Hi guys just a quick question relating to a quote i got from Pedders suspension in Campbell field VIC
i have a vz executive 06 and the strut tower upper bearings/bushes are now non existing and im also booked in for new pedders shocks
i was just wondering if my quote sounded right
4x Pedders lowered shock absorbs (car has been lowered 50mm)
2x front strut tower bearings/bushes
(I'm aware that ill need a wheel alignment but i want to let the shocks settle in before hand)
$820 fitted dose this sound correct ?
its booked in for the 9th of march (Saturday) so i have plenty of time to cancel if it sounds to pricey any thoughts ?
Doloth
VZ Calais
Sounds about right, depending on the struts/shocks being used
Aprox $100-150 per front strut
$70-120 per rear shock
$100 for strut top mounts + bearings
+ misc items such as new knuckle bolts
+ labour
rowe147
33
VZ executive
i thought it sounded fair but wasn't 100% i had never had to get this done before i also appreciate that quick response
cheers, rowe147
Ian Johnston
Mount Gambier, SA
2015 Subaru Forester, XR6 turbo ute.
Whats with the bull about letting the shocks "settle" in?? Will make no difference to your allignment. If it was new springs, maybe so, but not shockers.
Doloth
VZ Calais
Agreed, the struts and shocks won't settle, only new springs would. You should definitely get an alignment done in the same job... Should only be another $80 or so
Benboy
Hill River, SA
2007 SVZ Wagon
Don't pay extra for the wheel alignment, get them to include it considering the prices they are already quoting.
Ian Johnston
Mount Gambier, SA
Agree, w/allign should be part of the job, not extra.
WazzaVN
Wazza VN
VZ 6ltr ute, VP Calais and HJ Prem
They will do an aignment as soon as they touch the strut towers. $800 is about right. You could get Monroe gt's and strut tops and do it all yourself for about 350 - 450. But that all depends on if you're confident pulling appart your struts. They can be a bit of a headache if you've never pulled them appart before. But I'm sure there would be pleanty of guides on here.
greenacc
Searching for the billion
VE Berlina
I hope that quote is for sports rider shocks, or comfort gas at the very least. Thats about 500 parts plus labour
shaness8
Melb
FG F6 VX SS
That's cheap mate, they quoted me $750 for sports rider shocks supply only.
