Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree1Likes
Thread: removing side mirrors
    VN V6 Executive Sedan
    Nov 2008
    Default removing side mirrors
    Hey guys, once again I need help :-( Can anyone tell me how to remove the side mirrors on a VZ executive sedan?? also, does anyone know how to remove the motor that moves the mirror? Thanks again for any and all suggestions and help. :-)
    2007 SVZ Wagon
    Aug 2007
    Hill River, SA
    Nov 2008
    reinstall what?? there is no further info in your answer just to reinstall after removal process. help??
    holdenvtman1123's Avatar
    holdenvtman1123 is offline Improvise Adapt Overcome
    VZ Adventra LX6 2006 3.6L
    Sep 2008
    Broken Hill NSW
    1 Remove fuse F15 from the passenger compartment fuse panel.
    2 Remove the mirror inner dress cover (1) by gently
    prising the cover away from the door and sliding it
    back (towards the side window).
    3 Pull the door demist duct (2) up and out of the door
    trim panel.
    4 Remove the front door trim panel assembly to
    gain access to the retaining screws.
    5 Peel back the exterior rear-view mirror self-adhesive
    seal (1).
    6 Remove the three screws (2) attaching the exterior
    rear-view mirror assembly (3) to the front door
    assembly.
    7 While supporting the exterior door rear-view mirror,
    disconnect the wiring connector (4) and remove the
    exterior rear-view mirror.
    Sep 2008
    Broken Hill NSW
    tthe different steps to removing the trim are
    1.
    Front Door Remote Inner Handle
    Assembly
    Remove
    1 Prise off the remote inner handle bolt finisher cap (1).
    2 Remove the screw (2) attaching the remote inner
    handle assembly (3) to the trim panel.
    3 Remove the remote inne r handle assembly in a
    forward direction and unhook the remote control
    rod (4) from the handle assembly.
    Reinstall
    Re installation of the front door remote inner handle assembly is the reverse of the removal procedure, noting the
    following:
    1 Ensure the remote inner handle assembly and t he remote control rod are engaged before final fitment.
    2 Tighten the remote inner handle assembly attaching screw to the correct torque specification.
    2.
    Remove inner door opener and locking knob
    1 As required, remove the remote inner handle assembly, refer to 2.3 Front Door Remote Inner Handle Assembly.
    2 Insert a small flat bladed screwdriver or scribe (1) in
    the slot (2) below the red locking insert (3).
    3 Gently prise the red locking insert from the locking rod
    knob (4), taking care not to damage the knob.
    4 Lift-up the locking rod knob to separate it from the
    locking rod (5) and remove.
    5 Remove the screw (6) attaching the locking rod knob
    escutcheon (7) to the inner panel assembly and
    remove the escutcheon.
    6 Through the remote inner handle assembly
    aperture (1), remove the screw (2) attaching the trim
    panel assembly to the inner panel assembly.
    7 Gently prise the front edge of the window defogger
    outlet (1) and remove to the rear.
    8 Remove the seven screws (1) attaching the trim panel
    Take care while removing the trim panel
    assembly as the wiring harness connectors
    are still connected.
    9 Lift the top of the trim panel assembly, up and out of
    the door inner channel.
    10 While supporting the trim panel assembly, disconnect
    all the wiring harness connectors.
    11 Remove the trim panel assembly.
    Nov 2008
    Nov 2008
    do u have any illustrations to go with these instructions?? if u do, can u pleas post?? thanks
    Nov 2008
    does anyone have any pictures to go with these instructions??? please......thanks
    Sep 2008
    Broken Hill NSW
    Nov 2008
    Thanks. appreciate it
  1. Removing Mirrors
    By Robbo VS3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2010, 09:20 AM
  2. How to remove driver side button for side mirrors?
    By SupremeVT98 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-07-2009, 08:14 PM
  3. Removing Mirrors
    By smyth in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-10-2006, 04:55 PM
  4. Removing Side Mirrors
    By ciaranvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2006, 10:54 AM
  5. VX Side mirrors<--> to VY
    By AlX in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-10-2005, 10:46 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
