esp failed
holdenvtman1123
Improvise Adapt Overcome
Broken Hill NSW
www.google.com.au
VZ Adventra LX6 2006 3.6L
Driving along and warning came up 'esp failed'. Now says esp off.no code thrown
holdenvtman1123
Broken Hill NSW
www.google.com.au
After restarting the car the fault disappeared and came back after about ten minutes driving. Perhaps theres a problem with the abs unit? I know esp using the brakes to work.with no code registered im not sure where to start looking
Sent from my GT-I9300 using Tapatalk
holdenvtman1123
Broken Hill NSW
www.google.com.au
Would my abs affect my esp? Perhaps my bcm is losing connection with the abs creating an esp error?
holdenvtman1123
Broken Hill NSW
www.google.com.au
update. when i purchased the vehicle the level air ride pump was disconnected, stopping the pump from burning out because the air-bags on the shocks look like they have had it.
bit the bullet to find out why esp failed was appearing. Holden said ''codes P1632 C0460 relating to the disconnection of the air pump. this is the reason for esp failed coming on all the time''.
will buy new air shocks and reconnect the pump. hopefully problem solved.
code P1632 - theft deterrent fuel disable signal received
code C0460 - steering position sensor malfunction
holdenvtman1123
Broken Hill NSW
www.google.com.au
I'm still a little stumped as to how the air pump affects your steering position sensor and the fuel signal.....
Peterbarcher
72
New Zealand
Adventra cx6
Ive got the same fault on mine "esp failed" took it to Holden dealer and they checked it with diagnostic thingie and saying its the "Yaw sensor" $2500.00 for the part and another $1500.00 to fit it .....seems a tad extreme can ya throw any light on this.
lowandslow
NSW
V2 III Monaro
Smithy2388
34
Orange
2005 holden wl stateman
I had the same deal. Esp failed on the dash has for ages. Finally took it to holden and they said the abs module need replacing and gave me a rediculas quote so i went and bought one off ebay and put it in and tha fault still comes up?
