Can anyone help with this fault code P0011 A camshaft position
Mad Pete
58
sydney west
2005 VZ SV6
P0011 A camshaft position - timing over advanced or system performance (Bank 1)
poor idle,bit down on performance,has a start-up rattle when cold maybe 3 seconds
but the longer i let it sit the longer the start-up rattle lasts maybe 4-5 seconds.
I did notice with the rocker covers off ,turning the engine by hand
on one of the plates on the front of the cam sprocket
made a funny rattle sound that didn't sound right.
any help would be very much appreciated..Cheers
jake383
05 hbd vz calais
if its alloytech dude more than likely stretched timing chains
BigSteve
30
Kings Park, Victoria,3021
VZ Executive MY06
your timing chain is stretched, its skipping a tooth, when you get a camshaft fault code, it means chains on its way out, and judging from your description," rattles on startup" its a chain
Mad Pete
58
sydney west
2005 VZ SV6
Well I just replaced the timing chains idler sprockets ect,
they needed doing,now have smooth idle and no startup rattle but
now its throwing a P0008 code
i run a diagnostic on the motor while running and seems the timing is fluctuating
between -1.5 , 0-0 , +1.5
could this be a Failed camshaft position sensor or camshaft position actuator solenoid ?
super6vt1998
victoria
VYII L67 Calais A4
How much did it cost you for the timing chain to be changed
Sent from my iPhone using Tapatalk
Mad Pete
58
sydney west
2005 VZ SV6
i paid $350 for a complete kit ,come from the States.
this is the complete list of parts needed to do a proper job..
12597307 Primary Timing Chain (revised) *
2-12589011 Secondary Timing Chain
12597413 Left Idler Gear
12597414 Right Idler gear
12590921 Crank Gear
12600461 Left Side Secondary Guide
12597418 Right Side Secondary Guide
12597417 Primary Upper Guide
12623513 Left Side Secondary Shoe
12623514 Right Side Secondary Shoe
12609261 Left Side Tensioner
12609259 Right Side Tensioner
12609263 Primary Tensioner
12641260 Right Side Valve Cover (revised) *
12647768 Left Valve Cover (revised) *
12640448 Oil pump
12566429 Water Outlet Gasket
12584040 Water Outlet o-ring
12634750 Water pump Gasket
12622550 Water pump seal
12608750 Front crank seal
4-12593717 Cam actuator seals
12598158 Upper and Lower intake gaskets
12378521 RTV
25177917 Oil filter cartridge
yool
62
Australia
2007 SVZ Ute, 2013 SS Ute
Thanks, my SVZ ute has a similar issue. Can you throw up a link to the kit?:beer chug:
Silverbird
(Blake)
54
VZ Executive Station Wagon
Hi Pete
Did you get to the bottom of this? Just interested to know. Parts list is excellent too very useful.
roddy_257
Holden
Hi Pete
Yea I'm facing the same problem on the lhs bank showing a code p0021 "A" Camshaft Position - Timing Over, how did you end up fixing this problem
