bcw61
- Sep 14, 2009
- 357
- 18
- 18
- Location
- Northern suburbs of Adelaide
- VZ 2005 Executive Wagon
Due to my continuing problems (overheating) and investigations with my vehicles Alloytec engine, I am trying to ascertain if my replacement engine is the correct broadcast code for use with LPG.
Accordingly, if someone has a list of Alloytec engine broadcast codes together with the corresponding engine specification (particularly if the engine is suitably adapted for use with LPG), that they could post up, it would be much appreciated. I just have a sneaking suspicion that my original LPG Alloytec engine may have been replaced with a non-LPG compatible engine.
FYI, my replacement Alloytec is broadcast code HBA - which I suspect may not be LPG compatible (I believe HNE may be the correct broadcast code for an LPG modified engine). This might go a long way to explain why I have continuing Alloytec engine problems.
