vz ss radiator problems-after ideas
corhijasna
51
Portland Victoria
gday one and all,
as above I have a weird problem I need some help with,
about or 4 weeks ago I had the radiator replaced in my car due to coolant loss,within a couple of days it started seeping and leaving pink residue around the cap etc,no big deal I thought.
I changed the oil the other day and discovered pink residue all over the exhaust,trans etc under the car,i have searched and can not seem to find any leaks etc.
I am going to take the car back tomorrow and get it checked but was wondering if anyone on here has any idea or had this problem before with what it may be
thanks
CONROD
SOMEWHERE in the land of OZ
VZ SS THUNDER 6.0l 6 Sp
If the original radiator hoses were reused and spring clamps are also used (original equip ) are the clamps in exactly the same position as prior to removing due to the indentations left by clamps . When the system is pressurised put your hand down and see if you can feel any trace of coolantwhere the bottom hose secures to the neck of the radiator.
corhijasna
51
Portland Victoria
gday conrod,yeah done all of that and all clamps were replaced ,old hoses though,i have checked and can't see any coolant leaking anywhere,it seems to be happening at speed through the top of the radiator as there is splatter(pink) over the belts etc,had her checked out this morning and the mechanic thinks it may be the cap even though it is only 5 months old,they apparently tested the cap when new radiator was installed and deemed it ok,so have installed a new cap today to see if it still happens and if it still does the mechanic will order a replacement radiator and replace it for free I hope
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
I'd be getting them to pressure test the system, just to rule out a leaking waterpump flinging coolant around the engine bay, or something similar before they blame it on the radiator.
XioiX1983
40
2005 V8 Adventra
Water pump maybe? That's what's my problem was.
corhijasna
51
Portland Victoria
that's what I thought too,but theres no leaks etc around the pump,they pressure tested the system with the old radiator and found a split in the tank which is why I had it replaced by them,i was told this morning they tested the system after the new system was installed and was ok so I was told,it seems to be coming out under pressure and at speed which is why the mechanic thinks it may be the cap,only time will tell unfortunately and I just have to bide my time and see how it goes I spose
thanks for all the replies and ideas fellas
Sabbath'
Redblock Jesus
Things can start to break down further down the track after a new radiator/component is installed. They wont always fail straight away, but sometimes the extra "pressure" can snowball.
corhijasna
51
Portland Victoria
thanks Sabbath,one thing usually leads to another lol,I think if I keep having these little problems I may rebuild the whole damn thing I think
XUV
HSV XUV & Raised Cross 8 Trayback
give it a clean, start it up and watch it and what Sabbath said,
the pressure probably went to the next weakest thing ,it could be a pin prick of a hole in a hose or gasket.
corhijasna
51
Portland Victoria
have done the above but am rchecking every day though,still can't seem to find any leaks
