TwoUpTourer
For the record I'm putting up this thread in case it helps someone doing a search for this problem.
VZ Commodore with factory LPG.
Six weeks ago my VZ Commodore suddenly overheated, dumping coolant out onto the road. Topped it up, made it home before it did it again.
Did another top up, this time bleeding air out of the top of the radiator via the screw at the top right (from drivers perspective), ensuring it was all full. Ran it again, and lots of the coolant ended up in the overflow tank. Siphoned it out, put it back in the filler cap, bled the radiator, and after the next short drive it was all back in the overflow tank.
Mechanic I knew said I had a small head gasket leak and combustion gases under load were being forced into the coolant, displacing the coolant into the overflow tank, and suggested doing first a carbon-monoxide test of the overflow tank to see if that what was happening. Negative result.
Another mechanic said he was replacing head gaskets on VZs at the rate of 2/month that caused this overheating. This is really bad. And expensive. Wanted to do a leak down test to determine which cylinder was leaking combustion gas. Also time consuming = $$$.
Went to a third guy, a radiator specialist, who said honestly he didn't know. But he did know someone with a $20k testing machine who could definitely test for carbon monoxide gas in the coolant.
At this point I was pretty dejected, as the car is in great condition, but the engine is cactus. Lots of opinions on this forum, gaskets, thermostats, not bled properly etc, but none ultimately close to the actual cause.
So I went to the fourth mechanic, who didn't even get up from under the vehicle he was working on and immediately said to me that it was my LPG converter. What the hell??? Said it was a known problem, that after 100,000km, the seals are prone to let LPG into the coolant. Said to turn off the LPG at the tank, not just the switch in the car, so that it forces the car to run out of gas, and run it on petrol for a while to see if the problem disappears.
BINGO! Instant cure!
Rang the Adelaide distributor(MegaGas) for the factory installed gas system to get a seal kit, and he said 'sure, a well known problem!". Bugger me dead. Six weeks of grief, and all it took was asking the right guys. Kit was $87.
Found a local LPG installer who changed it over in 90 minutes for $100 labour.
Turns out the installation notes say that at various intervals the 6 screws holding the lid on the LPG converter need to be nipped up, because there are 2 large rubber sheets sandwiched between top and bottom of the converter, and over time the rubber softens a little, leaving slack in the screws, and allowing LPG to leak through to the coolant. Just great.
Whilst this little pearl of wisdom is in the installation notes, it is NOT mentioned in the LPG service manual, so therefore your local mechanic doesn't know that the screws require tightening. In my case, the LPG mechanic who installed my new seals said that my screws were barely more than finger tight, so LPG leaked through into the coolant, and LPG expands 270 times its volume into gas, causing large amounts of coolant to be forced out into the overflow tank, and ultimately onto the road. I have the old seals, and coolant has crystalised onto the surface at one point where there shouldn't be any.
So $187 later, what was going to be an expensive disaster is cured. If I had followed some of the advice I was given, I would have split open a perfectly good engine, spent a lot of time and money fixing something that wasn't related to the problem, and a week later be back exactly where I started, LPG leaking through the converter into the coolant.
I had a gut feeling that why would an otherwise good motor at less than 140,000km suddenly develop a weak head gasket, so the lesson was to ask, ask, ask until someone had advice that made sense. As soon as mechanic 4 said it, I just knew he would be right as it fitted all the symptoms. And it was so simple to test.
MegaGas in Adeliade said any car with LPG that has an overheating problem, should turn off the gas at the tank first and test if the problem disappears. Good and cheap advice.
SEARCH TERMS: COMMODORE, VZ, OVERHEATING, COOLANT, OVERFLOW TANK, CONVERTER
