Mate I did some research into cooler IATs because of MaFless wandering like a drunk in the sun sucking in 70° over the radiator around town
heres one of the threads you might be interested in.
I packed in the investigation when I realised that the best solution was ethanol (e85) not only its cooling properties and manifold pressure effects but E85's resistance to knocking allowed it to withstand intake air temperatures all the way up to 130°C, and spark timing of 30° bTDC before knocking.
In other words induction and combustion are vastly improved and hardly dependent on IATs at all, except below 0°C.
Here's some good reading,
http://dspace.mit.edu/bitstream/handle/1721.1/59952/676953430.pdf see bottom of Page 39 and summary on page 51.
Simply change your fuel pump (~$150), swap injectors and get a flex fuel sensor (~$150). You can DIY tune using either software or pay a lad with a lappy either way is about $500 to calibrate and optimize.
112 RON, 40% less carbon and up to 50¢ a litre cheaper than 98.
