freefallin
- Sep 29, 2012
- 615
- 5
- 16
- Age
- 43
- Location
- UAE
- VY Berlina / VZ SS LS1
I just removed the steering rack off my VZ and noticed that when trying to get the pinion/steering shaft off the coupling shaft (you know the part where the steering column meets the steering rack. There is a 13mm? bolt/nut holding them together), the actual coupling and what it is connected to which is the steering column freely moves! Is that normal?
I don't mean it swivels, i mean its like the entire steering column is only firmly held in place and made stable by the rack, which in turn is only held in place by 2 bolts. Is this right?
Reason i am wondering is cz i noticed before the steering wheel would shake whenever i went over bumps. I am not talking about a shake that is caused by the tires moving which in turn causes the steering to shake/turn. I mean the entire column feels like it is shaking as if the column is directly in contact with the street.
Can anyone shed light on this plz?!
Cheers!
Cheers!
