Why is my engine cutting off when i slow down to stop or when i am hard turning?
freefallin
UAE
VY Berlina / VZ SS LS1
I guess the tile says it all.
It recently started doing it. It idles pretty smooth so no rough idle or anything. Drives pretty smooth and normal too...but ones i stop at a light or make a u-turn, ...nothing. Engine just shuts off suddenly, don't even notice its off until the steering wheel gets hard to turn or stepping on the gas pedal does nothing. Turn the key and it starts right up.
Any ideas what's going on.
And yeah its a 05 LS1 VZ SS.
Towcar
Auckland NZ
VX Berlina Wagon
does the idle raise slightly when you turn from left to right at a stand still?
What about when you go to neutral from park? When turning the air con on?
If not sounds like the IAC or similar, I know I have issues in my GF's falcon at the moment and need to replace this.
freefallin
UAE
Just figured it out. Turned out to be a loose wire/connector. Guest which one :)
DLFHUB666
GIT 'EERRR DONE!!!
39
Nhulunbuy NT
VX SS, PX Ford Ranger XLS Dual cab
- or + on the battery ????
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Yes they will. The battery completes the charging circuit.
TPS?
freefallin
UAE
- or on the battery ????
TPS?
Really? I remember disconnecting the battery while the car was running on numerous occasions...didn't effect anything. Only times it did was when i had bad alternators. Once i even swapped batteries while engine was running.
Anyways...TPS you say? Well, it would be a likely culprit for such conditions...however it was not in this occasion.
Im starting to think no one is going to get this.
SS-REX
42
THE GC-QLD
03-VY-SS-UTE
MAF Sensor plug?
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
You're really going to draw this out, aren't you?
