hi waly5, glad you got it sorted.
My VZ Adventra was making a loud sh-ing noise since i got it running again a couple weeks back, but i have been concentrating on other issues.
anyways, it sounded bad like if you make a really loud SHHHH!!!! sound(kinda high pitched light scraping sound).
at first it sounded like the water pump but i already replaced that a couple weeks back.
the belt itself looked ok but when i looked closely at the tensioner pulley arms while it was running, 1 was rock solid & the other had a slight wobble(2mm's) up & down.
so i removed the tensioner arm & idler complete.
i should state that the adventra has a tensioner on the right(drivers side) of the engine which is not blocked/covered by anything & requires nothing else to be loosend or removed prior. all i did was put the socket drive on the tensioner square hole & took the tension off the belt long enough to pull the belt off the pulley & out of the way.
the belt is the 'inside belt (of 2) so i just left it on & pushed it out of the way behind the pulley, being careful not to let the pulley pinch the belt as i let the tension off & it lifted back up into position.
it was only 1 bolt through the middle of the main tensioner arm to take the whole thing off.
next i removed the idler pulley from the tensioner which is 1 bolt which is accessed from behind the pulley (that's why you have to take the whole tensioner out, to get at it)
i held the pully in one hand & put my finger through the bearing inside the pulley & turned it, it did not turn smooth & tight, it felt coarse & loose.
i put the pulley in the wood vice not too tight as to bend the pulley out of round & tapped the bearing out using a hammer with a socket that was the same size as the bearing.
i'd bought a new bearing for $11 from repco.
i should state at this point that the repco has the incorrect diagrams & part numbers for the idler pulleys & tensioners on an adventra. it shows the diagram of a standard vz commodore which is way different. even when looking it up via my plate number.
will probably start another thread on that to warn others.
anyways.. i gave the pulley a very light swipe of grease inside to help the new bearing glide in & prevent corrosion, then gently tapped the new bearing into the pulley using the old bearing.
i had to tap a bit harder to get it all the way in & i kept checking how far to go by undoing from the vice & flipping over to look at it from the back(no point just whacking blindly eh).
then i put the pulley back on the tensioner arm & tightened the bolt, could've used loctite but just did it up firm, not mantight.
put it all back on & yay! nice & quiet now
took about 15-20 minutes which inluded cleaning the pulley & tensioner up.
even though waly5's problem was different to mine, i added this to the post in case someone else has a noisy belt or bearing noise & is looking to diagnose or fix.
anyone with half a brain, basic tools & patience can do this, i barely meet the criteria myself but somehow managed it.
peace all.
