gilign
- Sep 20, 2008
- 24
- 1
- 1
- Location
- sydney
- VZ Adventra Jacked up 2 inch plus on 225/60/17
I know its an adventra and not commodore. I hope nobody is offended.
Here goes!
After a few months of trying to work out the problems with it, my addy is in the shop for for a scheduled auto service.(after a few weeks in lay up trying to sort it)
I have a few questions for the 5L40E Automatic Transmission tech guys and girls out there!
1....What is the type of fluid these are sold with in VZ Adventra with the first service due at 150000klm. (sealed unit, no dipstick)
2....If I get codes ( I have a scan gauge) "lost communication to the drive train" and also get stupid codes like "fuel gauge fault see service dealer" "power train fault see service dealer"
these were here and there, not all the time.
Then after a while (few weeks trying to work out what these codes mean) using the scan gauge to scan and reset. It wont start sometimes, and then it will.
But after a few more weeks it not wont start, unless I short the starter relay. Would this point to ECU,especially if after the auto service done and Holden clear codes and it still comes back doing the same.
3....Has anybody changed the transfer case oil. I have some but haven't tried yet. ( see question 4)
4....Does anybody have the service manual. its on dvd and the only one i have found is the part number VZ102006, which is no longer available and it is a full dvd of all vz range. not just the addy. leaving me with no way of finding out the method and torque specs for bolts ect, how to replace inner control arm bushes( they are pressed in to the sub frame) what are the limits for backlash on drive shafts and transfer( I am mechanically minded but not a trusting sort to just try winging it along the way)I would like a few pages of that dvd if they can be printed. As there no longer available and holden wont release them for after market production. I see no problems for sharing this between friends and a little compensation for the trouble providing the postal service.
Over all It drives good goes through the gears until the codes come up. Then sometimes it chucks it in gears going down but not others times
The codes come back but not all the same. Every time I get new codes, they usually change.
I have looked into all codes on the net. cant recall all them now. and cars in shop with scan gauge. everything points to the ecu from what me and my brother can work out.
I have tried a hard reset by disconnecting battery overnight with hazards with an attempt to draw any held power in the ecu.
But u know holden they want 4 hr min diagnosing @ $121 hr.
The good news is the ECU is only $350 buks. plus there $$ for linking it to the PIM and BCM.
Any thoughts and experience welcome with this problem.
Thanks in advance.
Here goes!
Thanks in advance.
