So I've gone through just about all the threads out there, and nothing has solved my problem yet.
Before I call in the 'professionals' was hoping someone here would have the solution.
Ive included as much detail as I can, but skip to the bottom for the short version
History:
Used the car (05 VZ exec) regularly, using it last on a sunday.
Did not touch the car again until the next friday, when I moved if a few metres out of the way.
Didnt use again till the next tuesday, I started it up and put it in reverse and it died (I cant be certain it actually started, it sounded like it was borderline, and as I grabbed the shifter it all died)
Since then I have not been able to start the car.
It cranks on the verge of firing, sounds like its almost there, but never starts.
I never heard the fuel pump priming, and there was no pressure in the fuel rail.
So I replaced the fuel pump and fuel filter.
Now when I turn the key to 'on' sometimes the fuel pump primes, but most of the time it doesnt. There is also pressure in the fuel rail now.
I cannot find what conditions decide if the fuel pump will prime or not, but it primes probably less than 1 in 20 attempts (if it primes, the fuel pump relay clicks, otherwise the relay is silent).
Playing with the relay, I can get the fuel pump to pump continually by bridging the fuse. This leads me to think that the problem is not the pump, nor the wiring from the relay to the pump.
Makes me think it is something electrical, to do with controlling when the relay is activated (hopefully not ECU-related).
However, when I crank the engine, after a second or two, the fuel pump comes on (everytime) but only as the engine gives up cranking, then the pump turns off.
Also replaced the oil pressure sensor/switch, as that was overdue to be replaced,and I have heard it is linked in with the fuel pump circuit.
The rubber elbow from near the throttle body to the EVAP/purge line was also cracked, so I replaced that too.
When I turn the key, I get a low fuel message (i think the new fuel pump is not calibrated properly yet, but it has about 15-18 L in the tank)
Occasionally, and randomly, I will get a service vehicle soon message too.
Since the problem started, the engine has never run, not even for a few seconds. Gets to the point of almost starting (sounds like its about to start, or is starting), then gives up cranking and goes silent. Does the same thing whether I flick the key to start, or hold the key to start.
Battery has been checked, and swapped for a known working one out another commodore, but same result.
Spark plugs or injectors crossed my mind, but its unlikely these would all fail at once, so suddenly. (or is there a program in the computer that shuts it all down if it senses a problem with one)
Also, I have no problem with the immobilisation (red lock light goes away once key is in), and all the fuses and relays I have checked and swapped, theyre all fine.
Any help or suggestions would be much appreciated before I fork out some serious cash for call-out fees and the run-around from different mechanics and auto-electricians.
Thanks.
Short version:
car cranks but wont start
fuel pump and filter replaced
fuel pump now primes sometimes
when cranking, fuel pump comes on as engine sounds like its about to start, but then everything shuts down
History:
Thanks.
Short version:
