Has anyone fitted or got a SAAS oil pressure gauge, I have fitted a set of SAAS gauges oil/volts, Volts gauge works fine but cannot get the OP gauge to work, wiring is as instructed, nobody including saas in Vic can suggest what may be the problem, I have changed the OP sender and also tried a different gauge to no avail..
The sender has an open loop when engine is off and also has open loop when running, this to me is wrong but if someone could check there reading(multi metre) on there aftermarket sender. Iv been through all wiring again and again, maybe a silly fault but I cannot for life of me find it...
Any idea's or a reading from sender would be great.. Im pulling my hair out
