It's not timed
And whenever this sensor is triggered, that means you need to change oil or in some cases that the oil is strange
Where the sensor is located : i dont know
But if you change oil you need to remove the warning message
And if you start your car after deleting the message, and it appears again, well ... You have to check the sensor or even the oil that you used
