Morto
- Jul 22, 2014
- 3
- 0
- 0
- Age
- 62
- Location
- Portarlington
- commodore
Hi,
Have a vz commodore that has a liquid gas conversion. Has been running rough for a little while, took it to the mechanic and he put new plugs, made no difference, so I took it back and he put a new set of coils in. Still ran rough and almost immediately it threw up the code po202.
I put a new set of injectors in and it continued to miss and throw the same code, I guess I should have thought a bit about the gas injection as even if the injector was failing, the gas injection should have still worked ok. I pulled off the feeds to the coil and it seems to be missing on No 1 cyl (as you face the engine the 1st cylinder on the left hand side), i think p0202 should have been the first cylinder on the right side as you face the engine.
I have swapped the coil from cyl 1 to cyl 3 and it continued to miss on cyl 1. I then pulled the plug on cyl 1 and replaced it with a new one and guess what? It still misses, continues to throw po202 code.
Any advice would be appreciated.
