+ Reply to Thread
Results 1 to 3 of 3
Thread: SS Pedals on a SV6
    SV6's Avatar
    SV6
    SV6 is offline lookin for a WHITE boot SV6 Executive
    VZ SV6 A5
    Jun 2005
    Default SS Pedals on a SV6
    Does anyone know how to or has anyone tried fitting SS pedals to a SV6???
    I'm trying to fit a set to an Auto SV6 and the foot rest and brake pedals look like they will fit, but the accelerator pedal seems different. The pedal allows for a straight arm whereas my accelerator arm has kink at the end. Is this a V6 & V8 difference?
    Is there a difference between VY and VZ assemblys? Can I buy genuine pedals to suit my SV6? Do I need to replace the accelerator arm?
    Marks-VY's Avatar
    Marks-VY is offline I love cars Marks-VY Berlina
    VT2 Berlina
    Apr 2005
    I bought VZ alloy pedals off ebay, the accelerator pedal actaully came complete (electronic setup) so I had to remove the alloy pedal from it and put it on my cable set up.
    The arms were identical and the pedal fit with no problems although I had to do it out of the car to remove the split pin.
    05 VZ SV6 A5
    Nov 2005
    Quote Originally Posted by SV6
    Yes, I've done it and yes, you need to replace the whole ETC (Electronic Throttle Control) because as you've pointed out the arm on the original ETC is different. It does require a bit of fiddling about to remove and fit the new ETC .... there's a thread on ANOTHER FORUM about this ... it doesn't mention part numbers so I thought I'd post them here if anyone's keen on doing this.
    92183444 ETC - Main Assembly
    92113881 ETC - Alloy Pedal
    92174763 ETC - Pedal Spring
    92050573 ETC - Pin
    92164561 Footrest - Alloy
    92113886 Brake Pedal Cover - Alloy
+ Reply to Thread
  1. SS Pedals
    By SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-06-2006, 05:38 PM
  2. OMG Pedals
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 05:02 PM
  3. pedals
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2005, 03:46 PM
  4. Alloy Pedals
    By Utester in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-05-2005, 03:26 PM
  5. pedals
    By andyvys2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-05-2005, 09:47 PM
