VZ Wagon - annoying creaking noise
Silverbird
(Blake)
54
VZ Executive Station Wagon
Hi all
Over the last month or so, there is a creaking noise coming from the tailgate / cargo area of the wagon, only when going over bumpy roads. I've had the trims off the inside of the tailgate, checked everything in there, tightened up a couple of loose bits I found - but the sound is still there. It's getting pretty annoying - any suggestions appreciated.
Blake
CONROD
SOMEWHERE in the land of OZ
VZ SS THUNDER 6.0l 6 Sp
check inside the side pocket where the jack lives. Wrap a rag around the jack and see if that muffles the sound:idea:
Silverbird
(Blake)
54
Hi Conrod
Very sensible suggestion - thankyou - but I removed the jack and basically everything I had in the back of the wagon. Totally stumped.
gendi
Cessnock, NSW
06 VZ SVZ Wagon
You know what I have the same issue and haven't thought of it till now, if you ever find it make sure you post it.
DeanoV6
VZ Executive
My cargo Barrier was the cause of the creek in my VZ
Silverbird
(Blake)
54
Certainly will do that.
Good suggestion but no, I don't have a cargo barrier. In fact this is the first car in which I have not fitted one.
XioiX1983
40
2005 V8 Adventra
Check the pins at the top of the tailgate. Alsocheck the rear ssuspension rubbers.
Silverbird
(Blake)
54
Hi XioiX1983 - I had been giving thought to both of those things. What am I looking for with regard to the tail gate hinges?
Thanks and regards
Blake
Silverbird
(Blake)
54
Hit all the rubber below the deck with WD-40 (not the tyres, LOL). Will see if there's and difference tomorrow when I drive to work.
XioiX1983
40
2005 V8 Adventra
You are looking for any movement in the pins.
