Vz alloytec Engine Removal
Finally got the Engine removed - Big job lots of work after lots of advice & thinking i decided to Wheel the lot out the front of the car , Engine -Auto-K frame the lot , Bloody big job it was the easiest way as there is no way you can remove the bolts from the torque converter through a little hole that big , through the little plate under the bottom of the auto or through the starter motor hole & also to unbolt the auto from behind the rear of the engine , No room - I just took me time & unbolted every thing that i needed to from removed the radiator & all the hoses etc , I tagged all the plugs that i needed to unplug as there is some just a few alternator wires starter motor wires the battery wires & wires to the Ecu only 1 plug etc etc its easier if you rap some masking tape around them & write on them what they are ,unclip fuel lines & air manifold lines etc Unbolt the Exhaust from the flanges , cross member & the coolest part about it no auto trans fluid mess i unbolted the 3 bolts of the rubber mount on the yoke & the yoke stays in the auto , i had a trolley jack that had a steel plate welded to a pin so i could put that into the top of my trolley jack so i put that under the cross member , undid the brake lines put some plugs in the end of the lines so i wouldnt loose to much brake fluid , unclipped the 2 sensors , Undid the 2 top bolts for the struts , Undid the 4 bolts for the K frame & they are 2 different size heads on them , typical Holden before you remove the 4 K frame Bolts make sure you have a Engine crane or Jack under the K Frame I just used my 2 ton Engine crane to hold up the K Frame & i then put a piece of metal channel right across the under carriage behind the radiator on the sub frame & used a block & tackle to lift up the car , dont worry about trying to undo all the plugs & wiring behind the motor & on the auto , you can undo the the 2 big wiring plugs either side of the back of the Auto one has a blue pin in it you pull the pin & slide a small screw driver in there & it will come out & release the plug at the same time , once you lift it up a fair way you can get in there very easy to unplug every thing all the Auto & wiring behind the motor is on its own loom so you can unplug 1 plug behind the right hand side of the motor & thats the loom that goes through the left hand side firewall so you dont have to remove that big plug , all the autos wiring & 1 plug behind the left hand rear of the motor & that loom will sit on the left hand side top strut mount , To easy thanx Holden for that at least ya did some thing right, You dont have to remove any of the huge wiring loom on top of the motor , So funny with the alternator & Air con pump you remove the nuts from them & then have to screw out the long threaded shafts with a 8mm small socket , then when every thing was disconneted i just wheeled the K frame out withe the motor & auto , it was a big job all good though- Was some thing new & was totally different than FB EH HR HK HT HG HQ HJ HX WB WH VL VT VX VU , Wasnt hard Just a lot of stuffing around & thinking about what your doing was very interesting as to the new Alloytec Engines & design , A lot has changed , Hope this helps a lot of Commodore Fans out there & our big boy toys we love , If you need any help - I,m here to answer ya questions , Now just have to do it all backwards reinstalling the new Engine = LOl grrr Thanx to all that replied
