aszaheer
My car had broken engine mounts and recently it started vibrating pretty bad on idle and acceleration but would stop once the car started moving. I just had both my engine mounts replaced and decided to do all the front end bushes at the same time. The car has done around 188,000 km.
Since I got the work done the car still vibrates while accelerating though not as bad. It is most evident between 20-30 km/h and then stops after around 40 km/h. After that I can accelerate as much as I want with no vibration. I thought I was getting the vibration before coz of the engine mounts but the problem is still there after replacement. The mechanic said there might be a vacuum leak somewhere and even replaced a couple of pipes and checked for any loose connections which didn't really help.
I'm going back to the guy tomorrow to get the car checked properly and would like to know what you guys think could be causing the problem.
