alloytec sludge
My sister has a vz wagon 140000 k started making a noise drivers side top end she took it to a mechanic he said burnt oil put some crap in it to fix it few hundred $ later. anyway didn't work i thought it might be the chains so i pulled the rocker cover off and guess what, burnt oil alright no amount of flush could fix that you need a scaper.pulled the engine out stipped it down sump full of crap. main bearings 3 and 4 stuffed, getting crank linished new bearings, hot bathed block and heads, new gasket set, machined heads, reground valves,new head bolts, lifters,hope i fix it spent about 2 grand so far
