Would you replace the dashboard because of this...? (pics)
freefallin
UAE
VY Berlina / VZ SS LS1
Considering you know how to do the job and that you have a dashboard laying around and that the center console and the AC controls and head unit is already out (like you can see in the last pic below), would you replace your dashboard because of the crack in the pics below?
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
If this is a poll, then Yes
If you already have gone this far, then yes i would complete it.
freefallin
UAE
well didn't really remove the center console and the stuff in the pic above to pull the dash. That was for another job, which has been completed. I just discovered the crack while trying to get to the sun sensor.
Now I'm just wondering if I'm being too anal or if this would be something that most ppl would want to replace as well.
Silverbird
(Blake)
54
VZ Executive Station Wagon
Looking at the crack personally, I wouldn't replace it. Have you inquired to see if there is some sort of glue or solvent that will weld the fracture up?
freefallin
UAE
I was thinking of using 2 part epoxy. But before i get to that, i was wondering if the crack structurally effects the dash in a way that it would make noise.
XioiX1983
40
2005 V8 Adventra
That's a good point, I hate creaking cars. Epoxy and foam around to help insulate sound and vibration.
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
probably not worry about it - so many Commodores getting around with cracks in dashes. Try finding a VN dash in one bit - almost impossible. If it isn't creaking it will not do much for you. Hidden from sight.. in the event of a crash - new crumple zone lol.
Seriously not a lot of point in replacing it :)
Benboy
Hill River, SA
2007 SVZ Wagon
Get yourself some 'fender washers' from Supercheap etc. They have a large surface area and once in place should secure the fitting preventing it from further movement.
ConstantVelocity
ACT
VTII SS M6
Drill a hole through the ends of the crack, helps prevent spreading because the round hole is less of a stress concentration than the sharp end of a crack. Then smear 2-part epoxy over it. The slow-cure stuff is stronger than the 5 minute stuff. The larger washers are a good idea too.
