P1otr
Recently i have started to develop an engine balance issue in my auto vz sv6. Basically comes and goes - regardless if its cold or warm.
Its more of a balance issue around about 1200 to 2000 rpm and really hear the vibration through the front (more the left). It only happens under load (in gear) and i can get the noise to happen with brake on in drive and revving it up around that rpm range. When it happens at that rpm while the car is moving it doesn't loose any power just vibrates and i can accelerate above 2000 rpm and the vibration goes away. In Park or neutral the vibration is not there.
When i say vibration - it doesn't resonate through the steering wheel and doesn't feel like its in the gear box / rear of the car.
I went to Holden and at first they struggled to see the noise and then he turned on the a/c and he saw what was going on and said to come back when it happens all the time. I actually checked this out and found that the car runs pretty well and i won't to see the vibration until i turn on the A/C.
I went down to local mechanic and said it 90% the engine mount issue in the car. Before i book it in i wanted to get see if anyone here has had this issue and what was the fix.
