Need opinions on which diff gears
muzz2005vzute
Adelong NSW
2005 vz commodore ute
I've currently got an open diff with 3.08 gears in it and want to upgrade to an LSD. I've got a 2005 manual v6 ute. I'm tossing up whether to stick with 3.08 gears or go up to 3.4's. If I went to 3.4's would I need to get my speedo re calibrated? Also if anyone has 3.4's in a v6 manual, what revs does it sit on when your doing 100?
dsuth77
VF SS A6 UTE
check the tag on your diff it will state your ratio. I upgraded to a 3.08 lsd about 7% more than the 2.87 I had (I believe yours will be same).
the problem with going any bigger is 1st gear is already very low.
@ 100 klph in 6th is about 1850 rpm from memory (I will check tomorrow) its still too high for overtaking
you can easily adjust your speedo plug in a tech2 (my mechanic has one) you need to find the ppk (pulses per kilometre) value for your car (6600 ish from memory) divide it by your old diff ratio (ie 2.87) then times it by your new diff ratio (ie 3.08) and input the new value.
there was a page on the web on doing just this
dsuth77
VF SS A6 UTE
