maff811
Hi all,
I have tried to find an answer elsewhere without luck.
I have a 2005 VZ Commodore Acclaim. In recent times I have had a problem with the lock on the rear passenger side door. The first time the issue happened, I locked the car and the alarm went off. The reason for this was that the rear passenger side door did not lock. I locked it manually and then locked the car with the remote.
From this point on, the remote has only intermittently unlocked the rear passenger side door. I have never had any luck with it actually locking by using the remote.
I have a fair idea that it is the actuator that has failed, as the problem only occurs on one door. With this in mind, I tried to unlock the door in order to take the door skin off and get to the actuator. It was stuck to a point where I pulled the plastic lock in the door off the rod. I then tried using pliers to get hold of the rod, but after gradually applying firm pressure, it gave way to the point where I think it has come off.
I cannot open the door from the inside or the outside, so I have do idea how to get the door skin off.
Any advice?
Thanks
Any advice?
Thanks
