alloytec sludge
just installed my rebuilt v6 and auto hooked up all connections and everything. tried to crank it over nothing
I think the VZ fuel pump doesn't run all the time, as the regulator is built into the pump assembly. It runs up to pressure and waits for the fuel to be used. Over a period of time the pressure bleeds away if the ignition is not left switched on. From memory mine held operational pressure for about 30 minutes before it started to drop back.Can get it to crank by bridging terminals 30 87 on relay but no start cant hear fuel pump running
