jwaye2
- Nov 3, 2008
- 317
- 4
- 18
- Location
- Darwin
- VZ SVZ, LN167 Turbo Hilux, VSII Ute
Hi guys
Im wiring up some accessories in my VZ but I dont want aftermarket switches so im going to be using the spot behind the window switches on the centre console. Most will just have the rubber tray but as some of you will know some models have factory switches instead such as Traction control, ESP, Hill climb, bluetooth and window lock to name a few. The symbol on the switch is irrelevant at this point but im wandering which one you think would be the most suitable as just an on/off switch. The plug and wiring isnt an issue and i can order any of these switches from Holden. The only bit im having trouble with is the functioning on the switches. Some will activate when button is pushed down and some will switch off (I have a general idea on which does what but not 100%).
So if anyone has any of these in their car and is able to tell me how it functions that would be very helpful. Also im not asking anyone to go pulling console apart for me but if you happen to have easy access to the bottom of the switch a picture of the pins/plug and part number would be great.
Following part numbers I already have (function, colour, Part No). Please correct me if ive gotten any wrong.
Blank (black) GM-92111637
Blackout (black) GM-92165679
Bluetooth (??) GM-92172330
T/C (grey?) GM-92111643
Thank you
James
Thank you
James
