This a bit of an epistle, sorry about that. I have tried to cover some lubricating oil history and maybe where we are at today.
This was how lubricating oil compatibility was explained to me some years back.
In earlier days, the grade of engine oil, not synthetic types, was set by the cars' engineering people. The car manufacturer would require a certain oil quality, or specification, which the lube oil producers were producing and capable of producing at the time.
The oil producer tried to ensure that the new lube oil was backward compatible with earlier spec oils to minimise inventory and production line runs. Hence the back panel on retail packs of oils generally states that the oil meets certain specs for the modern engine, but is compatible or exceeds earlier formulations of engine oil.
The old engine oils grades, straight and multigrade evolved over the years. There was always debate about changing from one brand of SAE30 to another brand's SAE30 and then switching to the "new" multigrade was another debate.
The world's biggest consumer of lubricating oils in the early days was the US Government and their Defence Forces. Since the US government selected the lowest quote year to year, it was specified that the incoming lubricating oil brand was to be seamless and incur no extra costs. Basically, dump old engine oil, refill with the new brand oil. (eg. no flushing was to required between different contracted suppliers' products).
Good old Uncle Sam would buy from the cheapest supplier and that was that. Also it was good business to ensure that competing lube oil producers' products were compatible to take advantage of these oil supply contracts. The cost of flushing out old engine oil would have been prohibitive as each supplier's lube oil came on line in workshops etc. Government Warehousing locations, oil stock inventory levels and wastage, engine and equipment failure etc, would have been a nightmare if there was no brand compatibility.
With the advent of full synthetic and synthetic mixes can I presume brand change-over should be seamless as it was for the old straight mineral oils to multigrade etc.?
Maybe the US Government/Defence Force does not hold as much financial sway over lubrication oil producers as it used to. Maybe vehicle manufacturers now determine the service oils for their "fleet" and expect oil producers to manufacture oils to keep up with their engineering requirements (early turbo oil cooling problems spring to mind);
or, do oil producers disregard lucrative government supply contracts worldwide?
Maybe similar specific branded lines are still compatible.
