05_Vz_Lumina
Hi guys was wondering if i could get some help and opinions with my issue im having with my 2005 vz lumina a few weeks ago i had a small
accident couple houses down my street on some construction work cracked my oil sump on a massive step where the road ends and becomes gravel
so i turned around pulled in the driveweay and turned the car off (just a few seconds down the street) when i turned it off i checked and saw the sump was cracked and still gushing out oil.
i pushed it down the road my my mates the next day to a mechanic i know he changed the done a good job on changing the sump and checking for other damage that may have been caused he done all the usual checks to make sure everything was ok and assured my everything is fine and i saved the motor. but since then the motor was rustling really really badly i noticed he put **** loads of belt grip probably cos of the oil everywhere so i wiped a bit of it away and sprayed a little wd40 which helped make the rustling noise goes away heaps.
Since then the engine still makes somewhat between a rustling and whining noise mainly on startup and when accelerating sometimes it won't make hardly any noise at all and when i put my foot down i barely hear it again as to when im just driving normal.
im going to get my mechanic to take a look at this when i take it for next service oil,oil filter,spark plugs, intake manifold gasket already had the transmission and oil/filter changed couple thousand k's ago never really had any issues with this car as its been well looked after previously it also has 160.000kms if that matters
thanks in advance
thanks in advance
