chrispy89
- Aug 28, 2010
- 47
- 0
- 6
- Location
- yatina sa
- 05 6sp Manual VZ ute
yesterday driving my tonner,189k, the SVS light came on, came home, connected my tech 2 up and came up with P0521- oil pressure sensor range/performance code.
took it to my local mechanic who pressure tested the oil and came up with these figures
idle 300kpa (factory 69kpa)
@2000 rpm 550kpa (138kpa)
my mechanic said it could it could be either timing chains or relief valve stuck closed.
is this what it could be or is there something else.
they also told me if its the oil pump, the motor has to come out, would it be advisable to do anything else while the motor is out?
