Do stock vz struts fit a vt ? Also does vz rear springs and shocks fit a vt ?
V viss New Member Joined Mar 12, 2005 Messages 60 Reaction score 0 Points 0 Age 51 Members Ride VZ ACCLAIM Nov 11, 2014 #1 Do stock vz struts fit a vt ? Also does vz rear springs and shocks fit a vt ?
someguy360 Well-Known Member Joined Jan 29, 2011 Messages 4,116 Reaction score 6,593 Points 113 Location The Shed Members Ride Various Nov 11, 2014 #2 Struts - yes Rear springs - yes Rear shocks - maybe, can't remember off the top of my head but I would assume yes.
jwaye2 Member Joined Nov 3, 2008 Messages 317 Reaction score 4 Points 18 Location Darwin Members Ride VZ SVZ, LN167 Turbo Hilux, VSII Ute Nov 11, 2014 #3 Struts will fit but may need to change to VZ sway bar links aswell as earlier models use the bolt through type and most VZ use the double ball joint type.
MYVESSV8 Well-Known Member Joined Nov 28, 2009 Messages 3,074 Reaction score 330 Points 83 Location Brisbane/GoldCoast Members Ride VE 6LT M6 Nov 11, 2014 #4 some also had bolt one end and ball the other
