Shaun40
Hi guys, I've had my VZ 06 wagon, V6 since 104000kms. Religiously changed oil and air filter every 5000kms. I'm now at 134xxxkms and due to do the 5000km maintenance again, although I've notice that she is starting to run a little rough "missing" especially under acceleration (not heavy acceleration, more so on the incline and lightly accelerating to keep up the speed). After reading through the other posts I thinking I'm due to give the wagon a bit more than the usual lovin?
My 1st question is, is there any merit in fuel additives to run through the fuel system to clean it?
2nd, is there any merit in taking her for a country run to blow out the cobwebs? So to speak.
Should I be looking at changing injectors, timing belt anything else that maybe causing the rough running?
Cheers in advance if advice is available
