Sudden loss of power on highway
95Waghoon
at my house
VZ Executive wagon
Hey guys, I did a search but cant see anything exactly like my issue.
05 Vz alloytec 175 with 4 speed auto, 255,000k's. runs perfectly normally, with no oil leaks or issues etc.
Driving on the freeway a couple of weeks ago the gearbox felt like it slipped into overdrive, and then wont kick down gears. It feels like its lost 80% of its power even with the throttle all the way flat to the boards the speed continues to fall slowly like the brakes are on and the engine is kind of labouring. To fix it I just take my foot all the way off the gas for a split second, then back on and everything works perfectly again. Has been doing this on and off for these past couple of weeks, usually 2 or 3 times during a 40 minute freeway run at 110k/ph.
Im thinking throttle position sensor at a guess, but Im not really up on all these electrical/sensor type issues. Any advice would be great.
ari666
250,000 hits
XUV
HSV XUV & Raised Cross 8 Trayback
Is that motor fly by wire ?
XUV
Might be a cause or a faulty/sticky TPS -Throttle postion Sensor
95Waghoon
at my house
VZ Executive wagon
I thought it might be that or failing MAF. Is the TPS the black electrical part attached to the throttle/air intake under the bonnet or is it attached to the top of the actual accelerator pedal ?
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
It's located on the side of the throttle body, near the IAC......
95Waghoon
at my house
VZ Executive wagon
Thanks for the replies guys. Has anyone else had this issue ? It may also be limp home mode. Foot flat to the boards it continues to drop speed even on the flat. Im thinking of replacing the whole throttle body and drive by wire assembly (all one part), but would prefer someones advice if this sounds like the right move ?
99notout
VZ Equip Wagon
When was the last time you replaced the fuel filter?? Check the easy first!
Benboy
Hill River, SA
2007 SVZ Wagon
Haven't experienced similar problem (thank goodness) however if you haven't had the transmission serviced regularly don't overlook that as a likely contributor. Good luck.
