In the past few months or so, often I will go to crank my car, it starts and then stalls straight away. No errors displayed on dash.
If I hold the key in the start position it does run, but as soon as I release the key it stalls.
If I remove the plastic shroud around the steering column and give the plug that connects tot he key barrel a push it then seems to start no worries.
This one happens every now and then. The connector plug doesn't seems loose. Its not a voltage issue, or fuel.
I have checked with another key - still same issue. Is there any known issues with key barrel harness or anything?
