JarBro
- Nov 30, 2014
- 32
- 2
- 0
- Location
- Karratha
- VZ Executive Wagon
Hi guys, just replaced my leaking seal on my timing cover (vz 3.6l wagon)
Now the car will not start. It all seemed to go back together fine, the main things I move out of the way were steering pump, Air con and alternator and the ECU system.
I was able to leave the valve covers on.
The car turns over when trying to start and the first time it started for about 3secs then stalled, since then it does not seem to want to run.
One thing i noticed when putting the harmonic balancer back on was there did not seem to be a key of some description as the pulley had a cut out but I could not locate anything on the hub of crankshaft (is there suppose to be a key ?) - just wondering would this effect the operation as it is still spinning when the car is trying to start.
I have researched the CAS but for this alloytec it seems it is towards the back of the engine so I don't think this could be a problem.
I have not checked for spark/fuel or compression at this stage as I did not seem to go near these parts. The only other thing I can think of is the 2 big leads that go to the ECU got mixed up and threw a fuel low take to dealer fault but once i swapped the plugs over it fired up for the first time and lasted 3 seconds.
I dont think this would have caused any long term problems.
Anyways hoping a couple of experts can give me some pointers on where to look next, I have the haynes repair manual but find that very limited.
Thanks guys, will check back soon.
