Rear brake pads barely wearing??
aszaheer
Jeddah
VZ Lumina
Hi guys,
I bought new acdelco front and rear pads to replace around 6 months ago and only replaced the front ones coz the rear had more than half pad material remaining. Now after 30-40k km of mainly highway driving I decided to check & change all of them as the rear ones might be due now. The fronts were worn about 50-60% and the rear still look like they have more than half pad material remaining. Is this normal? Can the rear pads last 3-4 times longer than front pads?
smidey
Northland, New Zealand
VN SS WM 6L
that's typical for ever car i've owned except my VN SS with 13" wilwood slotted rotors up front, i'm probably changing 6 pads front to 1 rear haha
Brisbarnz
Vh sle
Usually wear 3 sets of fronts to one set of rears. Its normal.
Pollushon
Boost gives me a bar....
VY SS
As above, I've done two sets of rear pads since 2006. Lost count on the fronts, maybe 8 - 10 sets.
Skydrol
USA
Pontiac G8 GT
Interesting, on my VE one of the rear pads was closed to the metal. Front ones had about another 10,000 left on them.
When I bled the system, the right rear caliper had air in them. After that, I can feel the rear brakes doing their job.
aszaheer
Jeddah
VZ Lumina
Thanks for the replies guys! Good to know that atleast there are still some things ok in my car :yahoo:
lowandslow
NSW
V2 III Monaro
Yeah. The rear brakes do 2 fifths of f#ck all.
A9L
Donating Member
VZ Calais LS1
Depends how many skids you do I spose :)
TI3VOM
Here there and everywhere.
VT Commodore
A car is like a bike (be it motorbike or push bike) the front does around 80% on the braking and the rear does around 20%.
