Hi i just put a new head deck with sat/nav and a reverse camera into my 06 ute , i installed the camera first and ran the cable from the rear to the head deck . i removed all the removable panels inside the tray and followed the wiring harness up to the fuel and and then through a grommet in front of the tank then in behind the plastic panel behind the drivers seat along the door sill and behind the dash to the head deck took around 2.5 hours as i also had to remove the tray liner . i put the camera into the panel that the number plate is fixed to but on the right side . i hope this helps Bernie
