enginge missing
viccib
VN V6 Executive Sedan
Hi guys, would like to know if anyone knows what could be causing my VZ engine to have a miss in it. I have had the coils and spark plugs replaced and the injectors taken out, checked and bathed but the miss is still there slightly. Any help would be heaps appreaciated :) Thanks
viccib
only when idling, when the choke is on and when the air conditioning is on
A9L
Donating Member
VZ Calais LS1
Aircon is a slight load. Done the leads?
viccib
not yet for the leads and there are no codes being shown by the computer either
diysv6
SEQ
VF S1 SV6 STORM A6: VZ S1 SV6 A5
Have you cleaned the Throttle Body butterfly area, the MAF and the IAT sensors yet?
Is the PCV metering hole clear, no cracked vacuum hoses etc.?
Is the purge valve solenoid working properly - stuck open, not clicking?
A9L
Donating Member
VZ Calais LS1
Low RPM misfire under load is usually plugs, coils or leads in my experience. Seeing as you've done plugs and coils, my bet is on the leads
viccib
ok thanks will check all of those things out too
diysv6
SEQ
I should have asked. What engine powers your VZ please?
viccib
it's a 6 cylinder and have had all of the above cleaned and checked. although the mechanic said there are no leads any other ideas would be appreciated and thanks so much for the help already offered
