Growley
I recently bought a VZ V6 Acclaim & the fan works but turning the selector knob doesn't do anything. The air only goes up to the front windscreen. I've currently got the dash surrounds out & everything seems to be connected. Any ideas? I've had a look at some other threads that seem to indicate a vacuum leak. Are there any common failure points? Not quite sure where to start in diagnosing a possible vacuum leak...
Edit: I found the tiny vacuum hose that has the one way valve was not connected to the back of the inlet manifold. Reattaching it didn't fix the problem.
