Hi guys,
Hoping someone can help shed some light on this issue which is driving me nuts.
My VZ has been running quite warm for the last couple of months when it's driven for longer than about 20 minutes.
It use to run at around 1/4 on the temp gauge but now gets to about half way but continues to get as high as 3/4 and just above before it miraculously does this two stage drop in temp.
What I've also noticed is that when it gets to 3/4 on the temp gauge, if you drop it into 3rd gear (which causes the revs to obviously increase), a few seconds later the temp starts to come down as per the below video link and return to where it once operated.
[video=youtube_share;aEeXn5_9LxE]http://youtu.be/aEeXn5_9LxE[/video]
Just some background to this - the radiator was replaced a few months ago, along with the radiator hoses and then the water pump started leaking so that was replaced with one from super cheap auto. I don't know if it's a coincidence, but the higher temp started soon after the water pump was replaced.
The system was purged of air traps, it's not loosing coolant, not boiling over and the cooling fans seem to be operating without a problem.
The thermostat hasn't been replaced, but I don't know if these symptoms relate to a faulty thermostat.
Any advice/previous experiences with similar problems would be appreciated.
Thanks all.
Thanks all.
