JarBro
- Nov 30, 2014
- 32
- 2
- 0
- Location
- Karratha
- VZ Executive Wagon
Hey guys, awhile ago I replaced the seal on my timing cover (commodore vz) when I put it back together it would crank and sounds like it should start but doesn't.
The faults I am getting are
P2229 Barometric Pressure Sensor Voltage high
P0521 Engine Coolant temperature Sensor circuit high voltage
P0197 Engine oil temperature voltage low
and the doozy
P0343 intake camshaft Position sensor high voltage bank 1
P0348 intake camshaft position sensor high voltage bank 2
Before the car got taken out of service there was no noise/rattle and the car ran like a dream with a minor leak out the timing cover.
I find it odd that all of a sudden there could be a possible stretched timing chain fault up and on both banks, seems to me rather odd.
I am in the process of replacing the cam sensors and cam position actuator solenoid and think I might just replace the engine wiring loom harness as well. Since I had to move all that aside perhaps it did some damage to the wiring internals.
Just wondering if people have any advice or ideas on what else could be causing all this ?
and the doozy
