takeing longer to start
VF Calais V
Randomly the car has been taking longer to start, this morning it took an extra 3 seconds and once started the dash beeped service soon the car has just be serviced with the reminder reset has anyone else had this problem i scanned the ecu for logged faults with none found the car is a vz calais v8 5.7 any help would be great
Also once started the engine runs perfectly!
satos
VZ Berlina
Maybe your battery is on it's way out.
A load tester will quickly tell the condition of your battery.
Recharge with a battery charger and see how you go.
SS-REX
42
THE GC-QLD
03-VY-SS-UTE
^^^ Agree also check your battery terminals and connections to for build up.
SS-REX
42
THE GC-QLD
03-VY-SS-UTE
battery is only a year old the terminals look fine
Have you done a load test if you don't have the gear(multi/E meter) just head to supercheap they can test it for you. Should be free but what in this world is these days....
petern64
60
Branxton NSW
vz ss 6lt , 2017 Mustang GT , 2021 BT50 SP
check your alternator with a multi meter, should be charging 13 volts plus
SS-REX
42
THE GC-QLD
03-VY-SS-UTE
Oh just saw again it's a VZ put it in to engineering mode and you can see what the battery and alternator are doing. Sorry thought it was a VT...
satos
VZ Berlina
How do you put it into engineering mode as I have a VZ too.
