sshh
- Feb 26, 2013
- 40
- 0
- 6
- Location
- Melbourne
- 2004 VZ Berlina
Hi,
I have recently picked up a VZ Berlina 3.6 with just under 180,000 on the clock, after reading a few posts recently regarding sludging in these engines I would like to do a couple of 1000km oil and filter changes for piece of mind. (doesn't look too bad under the oil cap, and dealer had it serviced when I purchased)
Now even though a synthetic oil is recommended for these engines can I use a mineral 10w-30 (or 5w-30?) just for a couple of 1000km changes? then revert to synthetic for normal 5000km changes?
It has a slight metallic rattle at 1500rpm which after some research sounds like it is the exhaust heat shields or something loose in the cats or exhaust system (which is what it sounds like). I will get under to check it out however if its the heat shields is there a common way to fix it? bend them out/in further? tighten the bolts securing them?
The other annoying thing is the little bit of belt slip noise that I get at idle, at the moment it seems to do it more once the engine has warmed up. I have changed the idler pulley, tensioner assembly and the drive belt and the noise is less than before but still there. I read a couple of posts that suggests that the noise could be due to the PS pulley not being aligned properly from factory? Has anyone else gone further with this and found a fix?
The last two items I have is a squeaky steering wheel, sounds like I have to lube up where it goes through the firewall. How the hell do I get my hands up there with the ABS lines in the way from the top and the exhaust in the way from the bottom?
Also noisy (squeak/creek) brake pedal, I have tried to spray the pivot point on the brake pedal arm but it sounds like its coming from within the rubber boot that goes through the fire wall to the master cylinder??
Any help much appreciated.
