mrjayviper
1. so I replaced the dome ceiling lights with LEDs. It turns itself on when I open the door but won't turn off when I close the door. I can still use the switch to manually turn it off. The only thing I changed is to swap the +/- terminals (had to extend one of the + terminals as it's short). The negative wire is still connected to the 2 individual switches. Any ideas what could I have done wrong?
2. Is it possible to change the tail lights (brake/reversing. basically all the lights you can see at the back) to LEDs without touching the cables (i.e. reversing polarity again like in the dome lights)
Thanks very much
Thanks very much
