It is just like the headlight switch - get two flat bladed screwdrivers (not too big) and carefully lever the switch out at the 3 o'clock and 9 o'clock positions. Don't be in a rush to remove it - easy does it. You will see the clips start to emerge. Use one of the screwdrivers to fold back the vinyl dash covering and then repeat on the other side. Don't force it otherwise you will tear the vinyl. Eventually you will get it out. Disconnect the plug.
